Alternator not charging battery
Lift
Washington
Alright the alternator is really starting to irritate the hell out of me. I have gotten the alternator tested and it tested out like brand new. Im using the stock 2.8L harness and voltage regulator and i wired it based off the wiring diagram but for some reason its still not charging the battery. Can someone tell me the exact colors of wire coming off the voltage regulator and the wire colors from the alternator to the connector and what those wires go to? I want to make sure my wiring is correct and if it is i dont know whats going on, id assume the voltage regulator isnt working or something.. Thanks
Found out it was a bad voltage regulator, my wiring was fine.
