Alarm lock unlock issues
MrSan4d
New member but omg can’t count the times I’ve read up on some of your ideas and used your knowledge for projects and ideas! So I’m no spring chicken when it comes to wiring but I’m at a complete loss trying to get the keyless entry working. I have set up the relays according to a 5 wire set up but I can not determine where or even if I need to cut the switch wires as some people have said. Anyone have experience with negative triggers from the alarm and how I need to proceed? 93 ranger with stock power lock conversion done. I will also say I installed a cheap alarm before and know the system worked but have no way of telling if the triggers were positive which is the only reason I can come up with that I’m having this issue
