Mazanger
- Oct 17, 2012
- Manual
Well, I am a bit stumped here and would definitely appreciate any advice anyone would like to offer.
The truck: 1994 Mazda B4000 - 5speed - 4x4 - lots of miles
The symptoms:
First noticed an issue the day before everything fell apart, I was in 3rd gear getting on the freeway and had the pedal to the floor, the truck hesitated for a split second, and then kept chugging along. The next day I noticed another instance of the same, but it happened just these two times.
Then, driving down the road, the truck just bucked and lost power. Refused to rev under much of any load. I pulled over and the truck would idle perfectly, but giving it any gas would cause it to miss and hesitate. Before I get to the list of things I have fixed, I will mention that I have noticed a few different behaviors. Lightly applying the gas will usually allow me to rev the engine up to redline, but anything over about 75% throttle will cause it to stop and sit at whatever RPM it currently is at, and will not go any higher. I also have had instances where no amount of feathering the gas pedal will get it to rev past 1500. It's random. Also, a couple times while starting it cold, I have been able to floor the gas pedal a couple times and it will roar to redline just as normal, but after a few goes it will revert back to its current behavior. The only constant is it always idles perfectly.
Here is a video of the symptoms. https://www.youtube.com/watch?v=_BbPZM7x0bk. I know it is idling high in this video, I do not know why that is, as it usually idles right at 850, this is not typical of its current behavior. When I am in the truck looking at the tach and it is around 2k, that is with the pedal to floor.
I get two codes, Lean in bank 1 and 2.(172 & 176)
Things I have done so far:
Changed/cleaned MAF(junkyard special, no change between units)
Changed coil pack(same as MAF, no change)
New TPS(old one was out of spec, no change)
Found one sparkplug that looks to be running lean, replaced injector with new, changed all injector O-rings, no change)
New plugs all around
Wires are not new, but they are NGK's and about 2 years old
Checked fuel pressure at rail - 38 KOEO, 35 KOEO- Idle, 40 KOEO - WOT
Changed fuel filter and pump anyways, no change.
Cleaned IAC, looks good.
EGR appears to be opening and closing normally.
Checked around lower intake for leaks with starter fluid, no signs of leaking. I replaced the lower and upper gaskets last summer and bolts are all still torqued to spec.
Next I am going to check the trim on the O2 sensors, though unplugging them does nothing and will not put the ECU into open loop, nor throw any codes. I have checked the wiring and it appears to be fine. My next guess is that the ECU is bad. Part of my thinking with the ECU being bad is I did weld on the truck the day before it took a dump, and I never unhook the ECU/Battery because I live on the edge.
Anybody have any ideas? I have searched extensively and found a few people that have had the same probelm, but they never follow up with what the solution was. I am inclined to believe that their truck murdered them in their sleep, or their wives did after they spent stupid amounts of time and money trying to figure this out. I'd prefer a different outcome. Thanks!
The symptoms:
