DandysRanger
- Jan 31, 2012
- North of Atlanta
- My credo
- If you didn't build it; it's not really yours
Probably a good enough description of what it is doing...
I replaced the intake, tps, ect, act, EGR and cleaned the throttle body real well. It is idling a little high but otherwise runs really well. The only thing is it seems to be a little abrupt on the throttle. That is, when you are cruising along and you let off the throttle it is not smooth. It is rather abrupt. The same thing happens when you gas it from a cruise. It's like the throttle is snapping shut instead of gradually. Does that make sense? I thought the idle bypass is supposed to control that but it looks pretty new and I hate replacing stuff just because. It does not do it all the time but it does do it most of the time.
Ideas?
Ideas?
