junkfixr
Just changed the filter & pan gasket on my trans & now it won't move. I can hear and smell bands slipping and a grinding when I go into park.
The parts dealer gave me a "multi" trans fluid & i noticed it replaced Dexron III and Mercon. Is it possible the fluid is causing the problem since it's not Dexron II ?
I would think it would still move even with this fluid, right ? Should I go get some Dexron II or do you think it's just given up? I changed the fluid cause it spewed all the fluid out last night & after refilling I drove it 10 miles or so, and it was fine. It was working fine this morning before I dropped the pan. Any help or advice ? It would be greatly appreciated before I pull the pan & refill with different fluid. Thanks in advance.
