Paul Heiser
1999 Ford Ranger 3.0L 2WD with 4R44E transmission won't shift into 2nd automatically for me. Everything else is working though including manual 2nd gear.
I tested the pressures on the EPC side port, and they all checked out fine although I decided to replace the EPC solenoid anyway since these happen to be a problem frequently on this transmission series.
I rebuilt the transmission after the reverse band broke. I replaced all band and disc clutches, seals, gaskets, o rings, rear sprag, torque converter, EPC solenoid, and included a shift kit and boost valve kit from Superior Shift. 2nd gear worked before that...and no longer worked after that.
I upgraded both Forward and Intermediate Servos with the upgrades from AEJI. All they do is take servos, cut out grooves around their servo pins before and after the fluid channel ruts, and their o rings set in those grooves. The o rings seal it up in place of the metal to metal seal which eventually wears out the bore.
I air tested all of the bands and disc packs after assembly, and everything seemed to be moving. I torqued down the clutch bands to 12 foot lb, and turned them out 2 spins.
I'll appreciate any reply.
