JCyr8511
Hello all.... So I have a 1999 ranger with the off road package and 10" drum brakes in the rear. this past winter I had problems with the e-brake stuck on, new cables fixed that problem. More recently the rear brakes have been sticking slightly on until I would back up about ten feet. However as I'm going down the road the right rear will come back on and drag. This is usually accompanied by an audible bang along with the rear end squatting slightly. Not to mention the loss of speed and my left foot needing a little more weight to get down the road. It doesnt always do it, and sometimes it will start dragging at low speeds. (2-5mph) I've replaced all the hardware and adjusters, along with the drums and shoes. Just to give more info, when I take the wheel off I cannot spin the drum forward, only backwards, the adjusters are all the way in and this wasn't the case when I replaced all the parts about a week ago. After a visual inspection, I cannot find any problems, all springs cables, etc. are in the proper spot and nothing is missing...whats going on here??
