Leigh
- Jul 20, 2011
- Manual
Two weeks ago, started in neutral—Clutch-in-- Would not go into ANY gear-----
With the engine Off—Went into all gears with minimal effort.
A half hour later, I tried again, & it shifted normally—OK for a couple hundred miles “stop & Go” driving with no problems.
Today, moved easily through gears with engine OFF / clutch OUT no problem.
Started engine in neutral, but would not shift from neutral into any gear again.
I started it in 1st gear, clutch-in, & it shifted through the gears OK for awhile, but “soon” got “hung-up” again. I had to shut the engine OFF, & start it in 1st gear again to get home.
Truck's been “parked” for about & hour since previous incident--- I went out & tried “shifting” through the gears with engine OFF / clutch IN, & this time it was difficult to engage into any gear; so I started it in neutral / clutch-In as before, & this time I was able to shift effortlessly into any gear????
Whatever the problem is, it's intermittent!
Clutch reservoir is at correct level; & Transmission fluid replaced 1.000 miles ago.
Best regards,
Leigh
Best regards,
Leigh
