kroed11581
- Jan 29, 2008
- Age
- 43
- Hugo, MN
1998
197
- Automatic
1998 Exploder, SOHC. In the cold, it fires right up, revs up to 1500, then down to about 600, if it doesn't die at this point, it'll kick up to 1500 again and back down to 600. Usually it dies somewhere in this roller coaster of RPM's. Once warmed up, it runs just fine - acceleration is great, power is great. Only happens when cold. Check engine light revealed only general misfire, and misfire on the driver's side banks. I replaced plugs and wires. Plugs and oil changes show no water in combustion chamber or oil, so I'm not thinking intake manifold gasket. O2 sensors are all new. Air filter is new. Cleaned IAC and MAF. Ideas? I thought maybe fuel pump or filter, but why misfire codes on one bank of cylinders? Engine seems to have plenty of power once warmed up.
