Ranger_Lobo
I picked up a beat up 98 4.0 XLT and I'm trying to fix it up but basically I know nothing I'm learning as I go.
It definitely doesn't have original keys, they don't work on the doors. The starter relay seems to be missing, replaced with a wire going directly into the relay. The wire taps into the red/blue wire on the ignition cylinder.
My guess here based on a simple wiring diagram is that power from the ignition cylinder is going via the tapped wire straight into the fuse box, which is attached to the starter. But I don't get why you would do this.
My goal is to go to the dealer and get OEM keys + ignition cylinder thereby getting the doors to lock again. And also fix the relay and gets this back to normal. But if I undo the tapped wire I'm not sure what will happen?
Thanks for any help
Thanks for any help
