96 Ranger Replacement Brake/Hydraulic Lines with 4WABS?
skiwithjohn
I have a 96 Ranger with 4.0L engine and 4 wheel ABS. The brake/hydraulic line from the ABS module to the left front (drivers side) brake hose has rusted through. The other two brake/hydraulic lines are in bad shape with rust, too, but they are not leaking - yet. These lines all have a built in section of braided stainless flex hose on the stock lines.
Does anyone know if there is a company (or person) who makes prefabbed/prebent lines as direct replacements for these lines? Are those small braided stainless sections required for some reason with the 4 wheel ABS or are they simply to give the lines a little flexibility? Can I simply buy some brake/hydraulic line tubing and make my own lines even though they would not have that braided stainless hose section in them and still have a fully functioning 4 wheel ABS? if so, what size tubing? What fitting sizes for the ABS module end of the lines and the ends by the brake caliper hoses?
the flex portion of the lines is for movement between the body/ABS unit and the frame/hard line mount.
in the days of old several loops of tubing accomplished the task.
Thank you. I was able to find a NOS Ford brake line for my one that has a rust hole in it. I ordered that one and will use it as a reference to get the correct connectors and see exactly what tubing flair is used on each end to make replacements for the other two lines that are heavily rusted. I will add a couple loops to the lines I put together to accommodate the flexing.
