jvt321
I have been reading many posts on this issue, I "think" I know the problem, but I'd like to hear from more experienced people. Thank you!
Well, had issues that pointed to air in the clutch line. Hard to shift, and I read that one issue I had, "will shift if I turn it off" was related to an air bubble in either the master cylinder because of the angle it sits on the firewall, and the loop that is in the line for this model.
Reservoir was only down about 3/4 inch. Dirty.
A friend and I took out the line and master cylinder and bench bled it.
Moved it all angles, lightly tapping to remove air bubble. Numerous positions until no more bubbles and hydraulic was firm.
Put it back in and...the same. Maybe a little worse even.
So, I read on another post that the slave cylinder doesn't go "bad" really, it just leaks.
I looked at the reservoir this morning (only drove 2 blocks down an alley in 1st) and doesn't seem to have lost any.
Is it possible we actually did not get all the air out? And that's the problem?
Or, maybe there is a tiny leak in the slave cyl that allows air to come in?
Thanks for your help!
