Syko
- Apr 11, 2008
- Age
- 36
Another custom long arm build hah..
I got a little ahead of you guys so ill catch you up.
My plan is to swap the entire TTB axle in with extended arms, Ill be swapping over the knuckles over because they have new ball joints in them. Also using the stock radius arm mounts mounted back on the frame and moved back 12 inchs the length I extended the Radius arms.
This give me little down time as its my DD and gives me plenty of time to build it up. Ill be replacing the I Beam bushings, radius arm bushings, and wheel bearings, cutting out the port for the axle, and adding a c clip eliminator.
The Exploder.
1994 Sport 2dr 5speed, 3.73 gears, posi rear, open front, 5.5 inch superlift
Basically the 5.5 Superlift with stock radius arms is a pain in the ass. You can never get the proper caster and bushings never last.
The Donor. 3.73 Dana 35, complete besides wheel bearings. 50$
A little heat and to my surprise an electric impact gun made the tear down pretty easy.
clean up!
Paint.
Mock up. 2x2 .250 square tube cost me 65 bucks for 5 feet.
Welding!
Boxing in the radius arm
Im not a welder by any means but I think these will hold.
The perks of cutting with an angle grinder.. Setting yourself on fire!
I still need to open up the passenger side port for the axle shaft, c clip eliminator, paint the arms, and cleanup the pumpkin. Ive thought about painting it Orange but im kinda on the fence.
The Exploder.
clean up!
Paint.
Welding!
