94' Ranger
- Jan 17, 2021
- Southern California
- 3.0 V6
- Tire Size
- 15in rims + Falken AT3
So my fan clutch went out the other day (it started spinning my fan at belt speed at all times), I went to replace the clutch when I noticed hairline fractures in between every fan blade. I've seen this before on old fans before but these were obviously fresh fractures from the recent stress of spinning so fast based on the color of the exposed plastic cracks. I went looking around for a replacement fan at the local part stores and online but I could only find "Flex-a-lite" metal fans like THIS ONE.
Does anyone have experience with these fans? I'd prefer not to use an aftermarket metal fan BUT if they work just as well and are as reliable as my stock fan that lasted 29 years and 207,000 miles, I guess that is probably my best option.
Since I read on these forums that they do not make the original stock fans anymore, I am planning on heading to the Pick-a-Part to look for a replacement fan that isn't in too bad of shape. I went to the yard yesterday but was unable to find a suitable replacement in their ranger selection before I ran out of time. I was curious if anyone knows if there are other make/models that use the same fan, or at least one that I could make fit? Or am I stuck with Rangers and maybe Aerostars? Lastly, if anyone knows what years of
Rangers used the same fan as I do, that would be greatly appreciated.
Cheers guys
Cheers guys
