thebatpeople
- Jul 28, 2008
I am replacing my exhaust system (again). This time it needs to be replaced from the manifold back. There are two bolts that go through a flange into the manifold and hold the catalytic converter on. I am having a hell of a time getting these bolts out. Do they use threadlocker on these or is it just age?
I need to add fliud to my power steering pump often. Before I start replacing parts arbitrarily, I would like to know where these typically start leaking. Should I replace the hoses first? Should I go with a pump seal kit or just replace the whole assembly? Is there a chance that it is leaking from the gear box?
I also need to add fluid to my clutch reservoir. Where does this typically leak at? Could it be a master or slave cylinder failure?
Thanks
Thanks
