92 coolant flow
johnsonater
I just got done putting a '92 2.3 engine with only 40 thousand miles on it into my 93 ranger just one thing the '92 has a coolant passage going through the intake unlike the original '93 engine. So i just need to find a coolant flow chart for a '92 2.3.
The coolant to the intake comes from a T in the right heater hose...you can buy the T in most auto parts stores...it has a step-down to a 3/8" from the 5/8 heater hose...just connect the 3/8" hose to the intake and the 3/8 on the T...
Basically, you can split the current heater hose and plug in the T with the 3/8 outlet pointing towards the engine...run the hose behind the valve cover and into the intake...
