89 broncoII not running.. been sitting for a few years
MiniMe
I just Bought an 89 BroncoII that has been sitting for the past 3+ years. Going by the oil change sticker in the windshield its been driven about 2000 miles in the past 11 years. It will only run for a second if your spray gas in the intake. I have replaced the fuel pump and strainer assembly, fuel filter and have check the fuel pump relay and inertia switch, all are working as they should. I am getting gas all the way up to the schrader valve(pressure relief valve) up by the intake. If I let sit all day it will start for a sec without spraying anything into the intake. It almost sounds like it is sooo close to starting on its own, a cylinder fires every so often. Any suggestions as to where I should look next.
Thanks
Can you check your fuel pressure? It should be about 40psi. Some auto parts places have a loan a tool program.
Richard
Does it have old gas in the fuel tank? If so its probably had fuel sitting in the fuel system for all those years, and as a result everything is probably pretty dirty possibly clogged fuel injectors.
Have you checked if you have spark? Motors need three things to run fuel air and ignition.
Sent using Tapatalk
It did have old nasty gas and a bunch of crud in the bottom of the tank. I cleaned it all out. Doesnt an injector have a filter on top?It may be totally block with same crud that was in the tank. Can injectors be cleaned? How big of a job is it to get access to the injectors?
I'm not sure but from that link that Earl posted I believe they have a filter, but if there was crud in that fuel tank you can bet it is through the whole fuel system. Your best bet is to just install new injectors to start with, however I'd disconnect the fuel rail and fuel line and purge the system, in other words run fuel through everything without it connected to the engine to be sure you get the crud out of everything. Then before installing it put in a new fuel filter then hook everything back up. That should fix your problem. If not you may have a wiring issue or computer issue causing it not to get fuel.
This would also be my guess. That crap is probably though you're entire line by now.
Each injector does have a filter in the top of it.
Regardless, if they sat for years with fuel in them, it will have formed varnish past the filter anyway (and probably rust too.) I'd pull the fuel rail and every injector and clean it all out and possibly replace the injectors.
FYI, don't try to "test fire" them with the rail pulled and the injectors stuck into it... the fuel pressure in the rail is enough to blow them out and you'll just make a mess and break the injectors if they go flying.
Now how did you figure that out??? This has the sound of experience behind it! lol
Richard
Pulled the injectors out tonight and strip them of o rings cap and filter They were all brown and nasty.Got em soaking in some sea foam. I measured the resistance of each one and all measure in the 14 ohm range. Where can i find an injector rebuild kit that comes with filters? All im seeing dont come with filters, also what is best way to purge the fuel lines of all the nasty fuel.
Richard
Noooooo...I'd never do something like that... :icon_rofl:
That link above comes with filters? Is it really worth trying to rebuild the ones you have? Maybe score some good junkyard style ones would be easier.
For flushing your lines out, put the end of the line in a container and cycle the pump a few times. Should push most of it out. The line between the filter and fuel rail is pretty short so there shouldn't be a huge amount in there. Or unhook them and run carb cleaner through until it comes out clean.
I orders the injector rebuild kit online from RJM injection. I have not receive them yet and am wondering if I ever am. They will not answer phone or return emails. They say on there website that orders are shipped out faster than emails are answered. Is this place still in business?
Also.. Is there a way to check that im getting a power signal to the injectors without buying a noid light? I do have a pretty high tech Multi-Meter. Where do the injectors get their power from? I figure i can test the other electrical parts that could possible be related to my no starting problem while im waiting on my injector rebuild kit
I checked for 12v across the injector plug with my multi meter and am getting 12v with ignition turned on, not cranking. I also check with test light from frame ground and only lights on red wire.. what does this tell me? does this mean I will get injector pulse?
Again i dont know if anything is wrong with injector pulse. I was just ruling it in or out while im waiting on injector parts
