Walsh_19
So my 1987 ranger current has zero power, and the battery and ground connections are good same with the fusible links. Nothing in the cab turns on same with headlights and tail lights and it will not turn over.
Welcome Visitor! Please take a few seconds and Register
for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
Thank you,i definitely going to give that a try and see if it does the trickWelcome to TRS
Follow the positive battery cable to the Starter Relay post, that post is the Power Distribution point for the whole vehicle
Disconnect Negative cable or Positive cable from battery
Remove all the wires on this ONE POST, clean all of them
There will be at least 5 Fusible Links on this post
A fusible link is a short wire, 6", that is spliced to a vehicles 12volt power wire, its acts like a "slow blow" fuse
Head light switch has a fusible link on that post
Ignition switch(cab power) has a fusible link on that post
Alternator has fusible link on that post
Computer has a fusible link on that post
Power windows/door lock, and 4x4 system will have fusible links on the post
So all 12v power goes from battery positive thru that ONE post to the vehicle
And there is NO 12volts, unless there is also 0volts, Negative/Ground, electricity needs to flow in a "circuit", a circle
i.e. if you hook up 1 wire to a 12v bulb nothing happens, must have 2 wires, a 12v and a 0v
So Ground is very important, check and clean battery negative cables where they connect to engine and body and frame
