Pretty much stock front end on my 87 BII
I've recently encountered a problem with the steering. It seems to be most prevalent when I hit some bumps or an unusual direction change in the road surface affecting one wheel but not the other. Such as might be near a storm sewer.
In most cases it makes a very definite pull to the right. It doesn't just drift that way independent of where the wheel is pointing, but I can very definitely feel the pull in the steering wheel. When I correct it stops. It isn't necessarily changing my direction a whole lot but I feel if I weren't holding the wheel and resisting the pressure it probably cause some change in direction.
It has not exclusively been a pull to the right. It has pulled to the left although much less frequently with the same feel in the wheel but opposite direction.
In most instances steering is well behaved. Normal return to center coming out of turns. No vibration in the wheel at any speed.
Could this be a basic alignment issue? Its been a couple years since last alignment, I could have hit some nasty bumps.
When this started happening I took a look at the steering. I found the coupling between the pitman arm and the tie-rod to have a significant amount of play. So I replaced the tie-rod and while at it the inner tie-rod end for left hand wheel. The outer tie-rod ends I had replaced a couple years ago.
The only difference correcting that problem really made was the steering got a bit tighter and now I very definitely feel the pull in the wheel while before it wandered without as much feel.
The wheel bearings and ball joints seem to be okay.
I had a similar problem a couple years ago with wandering over bumps and un-even pavement. That turned out to be one of the tie-rod ends and when replaced steering was really precise.
I thought perhaps one of the new outer tie-rod ends is no good. They seemed okay when I looked though.
Any other thoughts what might be going on?
