kishy
I've just completed a mostly-full rebuild (bearings and seals only) on my '85 TK5 and figured some here might appreciate the photos.
Pics here:
This was prompted by excessive fluid loss around the slip yoke, caused by a worn extension housing bushing. The extension housing bushing can be replaced without a full teardown, but there was also input shaft bearing wear which could be detected by letting off the clutch pedal in neutral and hearing a subtle whirring noise. With the trans removed, input shaft lateral wiggle was minor but obvious so a whole bearing kit made sense to do.
It hasn't gone back into the truck yet, but will be soon. Some corners were cut here but none that are likely to present any issues, at least not for a lot of mileage hopefully.
Pics here:
