A few years ago I bought this 85 Ranger just after it broke a timing belt (2.3l). The other owner put a new timing belt on it but could not get it to start. I bought it and it sat in my back yard til about 2.5 months ago. I cleaned the fuel tank, fuel lines and added a sock to the pump. I just cleaned the fuel injectors this last Saturday. I could not find a fuel filter installed anywhere. The fuel pressure gauge shows 34psi at idle and jumps to 40 when accelerated. 40psi when the vacuum line is unplugged. The truck will only go 65mph in 5th gear. The truck had 30 9.5 15s on it when I bought it, I just put 235/75/15 on it. According to Tacomaworld (https://www.tacomaworld.com/tirecalc?tires=195-75r15-235-75r15) the 235s are 9% larger than the stock 195/75/15. According to the door sticker, the truck has 3.73 gears. Are the tires just too big or is there something else I should look into?
Other info: compression 145-150 all cylinders, oil pressure 45psi at idle, 60psi when revved up.
Parts replaced: master cylinder, brake booster, brake hoses, wheel cylinders, calipers, water pump, thermostat and housing, timing belt and adjuster, exhaust manifold, air filter and all the lug nuts.
Working on replacing the ignition switch and the key switch.
