Evilbronco
- Mar 25, 2012
- Manual
So i pulled the truck out of storage. It was durasparked before the winter. Got a motorcraft 2150 installed and swapped in #43 jets. Plugged all vacuum lines including the one on the choke and the back of the spacer. Timing set 10 degrees bdc. Egr blocked. Still running a cat with glass pack. Replaced the fuel filter a few days ago. I put in a new coil from a 78 mustang to match the rest of the ignition but it ran better with the tfi coil so i switched it back.
Ok now the problem. It starts great and runs normal for a split second than idles rough. After it warms for a few there is extreme hesitation at about 1/4 throttle. It pretty much about dies then recovers. Once it gets going it seems to go away in the higher rpms. Mostly noticable between shifting and taking off. Ive checked all that i can think of. Havent done a compression test yet. Anyone have any insight?
