$.82 part can save a $1340 Ford AOD transmission?
97RangerXLT
Forum Staff Member
GMRS Radio License
TRS 25th Anniversary
Anderson, IN
IN - USA
Other
2020 Ford Edge Titanium
Vehicle
Drive
2"
31"
http://www.rockauto.com/Newsletter/index.html
Check the article down the page for the explanation and pics
Interesting...
$0.82 Bushing Saves $1340 Ford Transmission
RockAuto
If you or a friend drives one of the millions of rear wheel drive Ford cars or pickups built in the 1980s and early 1990s with the four speed (AOD) automatic transmission, then drop everything and inspect the throttle valve bushing on that Ford!
The AOD transmission in my son’s 5.0L ’90 Lincoln Mark VII shifted a little slowly and slipped (unusual increase in engine rpm) a couple of times on the way home from the grocery store. We searched an excellent Mark VII forum (thelincolnmarkviiclub.org) and found urgent warnings about failed throttle valve bushings causing severe damage to AOD transmissions.
This little plastic bushing (original Ford part number, E0AZ7F330A) was part of almost every Ford rear wheel drive and front wheel drive automatic transmission shift linkage. Usually if a shift linkage bushing disintegrates from too much heat and/or age, then the transmission linkage might feel loose or bind up.
Unfortunately, on the AOD rear wheel drive transmission, this bushing was used to physically connect the throttle cable to the throttle valve rod that moves a cable regulating fluid pressure in the transmission. As seen in the photo, a pin on the throttle valve rod fits through a hole in a metal bracket attached to the throttle cable. The bushing holds the pin in place. Pressing the gas pedal moves the throttle cable that moves the cable running to the transmission.
A pin on the throttle valve rod fits through a hole in a metal bracket attached to the throttle cable
When the bushing falls apart, gravity pulls the pin out of the bracket on the throttle cable. The transmission no longer gets feedback from the throttle and does not maintain the appropriate transmission fluid pressure. The transmission slips and can burn up and fail in a short time.
The transmission in my son’s Lincoln seems to be working fine after I inserted a new bushing, but the slipping probably shortened its remaining life. Do not assume that everybody with old Fords must already know about this. I drove a 20+ year old Ford Crown Victoria 5.0L for eight years and never had any problem with its plastic bushing. I was just lucky. Check the bushing on any ‘80s and early ‘90s F-150s, Mustangs, Town Cars, etc., with the AOD transmission. Find new Shift Linkage Bushings in the RockAuto catalog under "Transmission-Automatic". This bushing (ATP LO28 or Dorman 74043) currently starts at $0.82 at RockAuto. A remanufactured Ford AOD transmission (Marshall 118113) currently costs about $1340. A new throttle valve bushing is definitely worthwhile preventative maintenance!
Tom Taylor,
RockAuto.com
I just saw the same post on a Mustang site. Remember when that turbine car almost won the Indy 500 but a $2.50 (???) bearing let go? Alsways good to hear problems passed around, by the time they come from Ford, you're broke.
Dave
I had a broken rubber vacuum T toast the tranny in my Buick a few years ago, so this doesn't suprise me.
That's been long known to any transmission guy since they came out. The underhood heat killed the plastic and it fell apart. If you had an acting up AOD that wasn't toast that's what you check first. Sadly though people are stupid and drive them til it's wasted. Only remember a few people that were smart enough to stop when it started to act up. Kept a bag of those things for a cheap and usually free repair that made good return customers.
It good knowledge for those of us that aren't tranny guru's. [I hope that doesn't sound like a put-down to projectnightmare, I don't know how else to phrase it.]
Thanks,
Richard
