79 302 With M5OD-R2 TRANNY
bowturkey
Freedom N.Y.
15”
I'm going to be using an older 302 with 28oz. Balance and the tranny is as M50D-R2 with the hydraulic clutch. Should I use the clutch plate and pressure plate for the older setup or the newer like say 90-92 ? Don't know if the older clutch and pressure plate would work with hyd. Clutch setup.
You need the older flywheel, but newer clutch kit to fit the year of the trans...
SVT
Thanks! That's what I thought was just checking to make sure.
