5r55e tcc solenoid HELP
kinoschmid
upstate NY
I am in the process of changing the TCC solenoid on a 1999 4.0 ford ranger xlt. The new one I got from napa has a screen in it ,the one i took out doesn't and the numbers are different on the solenoid but other than that it looks the same NAPA Part#1-6504 bag says CS-2002 is this the correct one??
put it in, alot of time when you flush an older trans, the vb gasket blows and garbage gets in the solenoids, so when you clean the VB and reinstall you still have a solenoid issue, this is just extra protection. go ahead and install it securely,s lowly and properly, and you should be able to drive off
