5.0 Swap
PNW Redneck
U.S. Military - Active
Fort Sill OK
I know the 5.0 swap has been done a billion times. Im heavily considering doing it and am already aware of the wiring and computer issues that may and will pop up. What im asking is will the T56 Trans bolt to an 01 5.0 out of an explorer, and are there any adapter plates or ways to bolt a TCase to it? or bolt the explorers AWD TCase to it?
Itl be going in 03 4.0 4wd ranger, and i would very very much like to keep 4wd, and swap it to manual.
T56 has 2 Overdrive gears, so not seeing a good reason to use it in a 4x4, so top speed oriented not ratio oriented
Gears 1 to 4 are same as most 5 speeds, a 0.75 OD(like 5 speed) then another 0.50 OD
Yes, adapter plates are available, but pricey: https://www.cjponyparts.com/conversion-bellhousing-t-56-289-302-351w-351c/p/BELL14/
No, as far as I know the T56 was never used in a 4x4 or AWD, so no 4x4 tail shaft
T56 was used in these vehicles: https://en.wikipedia.org/wiki/Borg-Warner_T-56_transmission
Google: t56 2wd to 4wd conversion
Some have done it
