Anyone know or have a wiring diagram of what needs to be done to make a 4.0 starter work in my '86 BII? I am swapping in a M50D-R1 and will have to use the 4.0 clutch and starter.
So it is a trigger wire that goes on the relay (on the same side as my present starter wire correct?)For the relay to solenoid, almost anything will work (I doubt it carries even an amp). #14 or #16 should be fine.
