Transmarobirdeater
Im having problems with my 4.0. Im not sure were too post this because it is a completed swap. I have an 04 explorer 4.0 in a 2000 ranger that was origanally a 3.0 flex fuel 5 speed standard. I have 20,000 miles on the swap so far. Its been driving great. I had an issue with the fuel pump relay buzzing on start up. It seems like the light blue and orange wire that is grounded through the PCM to turn the fuel pump relay on is not working properly. I ran a jumper to this wire and grounded it and turned my fuel pump relay on and off a few times just to make sure i was on the right path. Now I have developed a whole new issue. Now the PCM is not grounding that wire at all. I have too stick a jumper wire in the relay box just too get my fuel pump too come on also when i try to start the engine i have too give it gas too keep it running and it runs real rough like its missing and the exhaust gets way too hot after a couple of minutes. As soon as I let off the gas it dies. What the hell did I do what would cause my motor to do this. It was running like a top right before I messed with the fuel pump relay wire. Need help!
