351 Cleveland Ranger
Pics aren't that clear but it looks like 2V heads?
what manifolds are you using that will clear the steering shaft? Are those 2bbl heads with a 4bbl intake?
That's a Big ass mill. What are the specs?
1970 351 Cleveland with 2V heads with 2.04" intake valves and 1.65" exhaust valves, forged steel rods, cam .248/.250 lift, 9.5:1 compression ratio, 1.73:1 rocker arms, 50K Volt Procomp racing distributor and 9mm wires, Edelbrock dual plane aluminum intake with Holley 650 (vacuum secondaries), Edelbrock air cleaner, double-roller timing chain/gears, Procomp electric fuel pump, steel motor mounts, and serpine belt conversion.
