302 efi swap for a beginner
hiniker88
I recently bought a 91 ranger that needs some work. I also have a 94 bronco that needs work. I was thinking i could take the engine, trans and transfer case and stick it into the ranger. I am getting the complete wiring diagram for the v8. I was wondering if i should get the mustang upper intake or if the one out of the bronco will work.
Sent from my DROID RAZR using Tapatalk 2
Need more info:
What trans is in the Bronco? What T-case?
The upper from the Bronco should fit fine. It's only a couple inches taller than a carb/air cleaner setup. There may be a clearance issue with the tcase, but I'm not completely sure of this. RangerSVT would be the one to ask.
