2002rangerv6xlt
- Jan 21, 2013
- Manual
Gents, I'm going to change my timing chain on my 3.0L and am thinking about just removing the front bumper and grill to make things easier. From other posts I gather this is pretty straightforward. Any thoughts?
I'm changing the chain because I have a rattling noise that initiates when my throttle input changes sharply from low to mid throttle position. I performed a compression test and everything came back fine. My tranny is also fine, so I'm guessing it's the timing chain.
I'm also planning on changing my coolant lines, the water pump, power steering seals (one is leaking) and the oil pan gasket while I have things torn down.
Do you guys recommend replacing anything else as preventative maintenance? I've got about 170,000 mi on my truck now and want to keep it going.
