mctavish
- Jan 24, 2015
- Automatic
Hi everyone. I am about to change my cam synchro and sensor. I have read all the info here and watched a couple videos and have a question about the position of the cam synchro housing. I know the vane inside the synchro has to be marked in the same position on the synchro but does it matter how the whole assembly matches the manifold? ie. If the vane is still inline with the synchro , does it matter if the synchro body is off a couple of degrees compared to the manifold? I ask the question because the hold down bolt can be tightened down anywhere on the cam synchro body. Thank you.
