flyfisher1757
- Jul 6, 2017
- Automatic
My 2004 Ford Ranger XLT 3.0L, 75K miles will NOT re-start on a hot / humid day. When cold, it starts and runs great. If I shut it down after driving around a bit, the engine will crank normally, but will NOT start, no matter what. I've been stranded a few times now.
I've changed out the spark plugs, fuel pump relay, the coolant temp sensor, the thermostat and put in fresh coolant. Checked the inertia switch, it seems ok. No blown fuses that I can see. I asked my local Autozone if they could pull some codes for me, they said they wouldn't touch it unless the Check Engine light was on (which it isn't). WTF.
When trying to start it hot, I watched the RPM guage, it seems to stay at 0 until the engine coughs, then it indicates a few hundred RPMs, so it seems like crankshaft sensor is working. I popped the gas cap off and turned the key on, didn't notice any primer pump hum / noise, but maybe too much outside racket to tell.
Ok, so I was thinking maybe the fuel pump, but once I get the truck running, it stays running fine / steady. I would think that a bad fuel pump would cause it to stop running at some point, but not sure.
Anyone have any experience with this issue...?? Any suggestions...??
It's driving me nuts. HELP!!
