2002 xlt 3.0 radiator fan warped?
Blakesgst
Hey guys, did some maintenance today. I noticed the radiator fan on my 02 was a bit wobbly, perhaps warped? I changed the fan clutch, idler pulley and, belt tensioner pulley today and the fan is still a wobbling. I checked the water pump play, seems tight and fine. I do live in the desert and the truck does sit outside most of the time, is it possible it has warped? Maybe my water pump shaft bent somehow?
Blake
Check for cracking at the hub if it is a plastic fan, they are great for doing that with age.
Did you check the pump with the belt off? Otherwise you will be fighting the tensioner... and it will win.
