gpmiller78
Guys,
Need a little help here. I have 2001 sohc with 2004 harness. have the pats programmed working fine. Starter, and fuel pump work. But I have no power to the coil pack. I checked the PCM relay and fuses all good. I keep seeing something about a PCM relay diode but with the 2004 harness it seems as if they took out of the battery fuse panel under the hood. If that could be the issue where in the world would it be?
