Whiskey990
Hello,
Well...yea my climate control works just peachy but isn't lit up at all. I pulled two bulbs out and one was burned out but the other wasn't. I installed two new bulbs (194 Red) that looked to be similar...but it still isn't lighting up.
Any idea if their are other bulbs I should be using or what else could be causing the problem?
Thanks a ton!
(That's handy..I'm actually having a New Castle)
UPDATE: Just in case anyone ever needs help with this...it was infact 194. My silly cheap red bulb just blew was all. I put in two trusty 194LL bulbs by Sylvania and it's been working great since.
Remember, you just remove the two screws above the climate control and pull the whole unit out..than the four holding in the climate control unit itself and the bulbs twist out.
Thanks a ton!
