Tazmain
I have a 1990 Ford Ranger XLT 2.9L ( 177ci ) v6. Should i rebuild the 2.9L or swap in a 289 v8?
A roller 302 has roller lifters instead of flat tappet. The rollers also make more power.Is there a difference between a 302 and a roller 302?
For this the revvy nature and much lighter weight of the 2.9 would be prefferable. If you stick a 302 up front its gonna sink the front end in the soft stuff like a rock.Well its 4x2 but I have a 12,000lb warn winch on the front for light mudding.
How much heavier is the 302?For this the revvy nature and much lighter weight of the 2.9 would be prefferable. If you stick a 302 up front its gonna sink the front end in the soft stuff like a rock.
That's my memory as well. You could balance that with aluminum heads if you really wanted. It's definitely not enough to 'sink the front end in the soft stuff like a rock'.I have always heard less than a hundred pounds... so not really that much.
