2.9 to 5.8 factory tach issue
merch
shreveport louisiana
does anyone know of or have a post of the procedure for making my factory 2.9 tach read with a 351w? ive searched for threads or tech articles but not any specific how to's. has anyone doen this,and if so any pics?
Mid 90 explorers have the same dash as my 91,are the tachs different between the two?
Sent from my DROIDX using Tapatalk 2
i see your avoiding corrupting the other thread.
attachment.php
so one wire is black and yellow and the sig wire is tan or pink...theres several colors for them and some go thru the pcm.
if you have the blk yl at the 8 cyl and it has ground continuity, then popping it out of the plug and leaving it ungrounded should be the 8 cyl setting.
i remember some with 6/8 on the back but that may be confused with mustang and 150 stuff.
i tried finding it on the rrorc but its gone now and i have no access to it anymore.
I remember it was posted in a tech article but I cant find it either. Ill try yo remove the 8 lug like you mentioned
well theres quite a few types over the ford and gm lines i have dealt with and having pulled back from this type of stuff the last 5 years its just not on the window in my tiny little mind. most rigs end up with real gauges and the factory junk is left to the trash can.
True,but I like my dash and rraly want to keep it and have it work if ots even possible at this point.if not ill cut it out and make a new one! Haha
