justincreager
Hey guys. I've seen people post the same problem or something close but no one ever seems to post a reply addressing if the issue got fixed or how to fix it. In this case I could really use the help and an answer of what it is that's causing the problem and not so much possibilities.
So to start like the title says, when I'm driving along at a steady rpm in 5th gear it will begin to stutter and 96% of the time stall out. While I'm coasting most of the time I'm able to put the clutch in crank it over and it will fire stutter a bit more then go away. The funny thing is when I drive the truck to and from work, it throws it's little stuttering stalling fit the same distance from both the locations about 2 or 3 miles from when I start driving.
I've replaced the heads (a year ago) but recently I've, replaced the O2 sensor, distributor cap, spark plugs and wires, fuel filter, fuel pump in the tank, fuel pump outside the tank, air filter and alternator, as well as had a fuel pressure test done that showed nothing was wrong the pressure.
The interesting thing I noticed today as it stalled out on me on the freeway in 5 o clock traffic was that when the stalling started it killed the power to my radio as if you were to pop the trunk and remove the power cable. All my programed stations were gone and settings erased. After sitting in traffic for a few minutes I was finally able to get it started with out any stuttering and drive home. In finding the fix to this problem does that complete loss of power make a difference? Thanks in advance for your help guys.
