1988xltsupercabranger
Greetings fellow 2.9 owners,
I bought this truck with a cracked head that ran excellent with zero issues and have installed 2 new aftermarket heads. Now it doesn't want to start unless I floor the accelerator and once it's running, its pretty rough/misfiring. I've replaced the MAP, IAC, O2, intake temp, coolant temp, TPS sensors, and purchased rebuilt injectors; timing is set 12deg btdc, new plugs/wires, fuel pressure is 40 and no fuel in vacuum line at FPR. Any suggestions on where to look next? Thinking I'll test every component of the ignition system next but I have a feeling there's a computer/wiring issue.
Any help is appreciated
Sam
Sam
