2.9 after everything that I've been through still nothing.
sexybluelady
springfield, ma
I've been having a hell of a time with my ranger. Short story, I was a victim of a hate crime at my college and my truck was vandalized at school by social justice warrior students, who thought the truck was owned by someone, who turned out to not be the case. They based their assumptions off of how the truck looks. It's old, and has huge tires on it a USMC sticker, they made up a picture in their heads as to who they thought the owner must be.
Fast forward three nearly four years later. And this is what I have done to try to get the truck running smoothly again.
Replaced the busted out windows
Brought new tires (old mickey's were slashed)
Dropped my fuel tank and cleaned it out.
Flushed out my fuel lines
Replaced my inline fuel pump
The in tank fuel pump
Fuel filter
new FPR
Did a tune up plugs and wires
Things that had to be done from it sitting while I gathered money and tried to fight the college to take responsibility.
New thermostat (other one was sized)
New clutch, slave cly
And flywheel
Fast forward to today. And sometimes it will fire right up, if you hit it with my starting fluid which screams fuel problem. BUT I have 35 PSI at the rails with the KOEF. My fuel injectors are pulsing, I put my node lights on them there all firing. I have a spare ECU that I use as a control, to see if my current ECU was bad. I checked my voltage readout on my TPS sensor (because it was hard to get it to idle) It was out of specs so I replaced it. My IAC is working fine. My timing is dead on. I even went ahead and replaced my timing chain because it was about that time for it to be replaced anyways.
The only thing that I have left in my head as to why my truck doesn't want to fire up on it's own is maybe my fuel injectors are clogged?
I am so depresate to get my truck back on the road, I've been through so much so far with my dear truck that I'm at my wits end as to what else it could be.:bawling: I just want my baby back dam-mit!!!!!!!!!
Oh and yes I have spark and compression.
fuel injectors full of crap maybe
pull top plentim .fuel rail and have a look
Yea that's the only thing I can think of that is left to do. I was thinking about just cleaning the injectors. But it may be more cost effective to just buy a whole set at $54 dollars. :/
Does it run fine once it starts up? If so, the fuel injectors are likely just fine and replacing them won't do anything.
How does the spark look?
Is it bright blue or dark orange?
Have you checked the points in the distributor?
Have you tested the TFI and the pickup coil inside the distributor?
Will the truck start more easily if you push start it?
How do the batter terminals and engine grounds look?
Sometimes when an engine is being cranked by the electric starter, the voltage drops enough that you get really weak spark or no spark at all. I had this problem with a Bronco 2 years ago. I would also check the resistance between all the wires that lead into the distributor from the distributor side to where the pig tail plugs into the main harness. If the shielded ground in that harness is cracked/broken even just a little bit you will get very weak spark and intermittent spark.
Hiya, yup my spark is bright blue, my cap and rotor are new, plugs and wires new, coil is new as well (replaced them when I did a tune up). Battery is new, connections are tight, and clean. Grounds are good. checked connections with a ohm meter. TFI is new I had a spare laying around along with a new dizzy.
For a bit it would start and I would have to baby the throttle until it warmed up or it would bog down and shut off. That is when I tested the TPS sensor and found that it was bad. I had also ruled out the injectors when it was starting with fluid. Then I didn't touch the truck for about a week. I went back to get it started and it wouldn't start. I hooked up the fuel pressure tester to see were my fuel pressure was at and I had zero at the rail. I remembered that the students had put crap in my tank and figured that it may have caused my regulator to fail. Because both New fuel pumps turn on, prime. I replaced my regulator and rechecked my fuel pressure. I then had 35PSI at the rails.
Then I went to start the truck after replacing the FPR and prime the fuel system a few times before starting and it wouldn't start. Sprayed some starting fluid it wants to start and catch so bad but chokes out. That is when I assumed that whatever crap was in the tank, before I dropped and cleaned it out and replaced my fuel pumps and filter must have moved it's way to my injectors after I had replaced the rest of my fuel system?
( I assumed this because the shops and tow drivers had tried to start my truck many times when I had the windows and tires replaced, that is before I found out something was put in the tank)
Oh I can't pop start my truck, I'm strong but not that strong. I can not move it while it's parked in the grass. I'm by myself, no help. My grandmother can't do anything and the rest of my family is beyond useless. Unless it has to do with watching tv and complaining.
update, I pulled the injectors today and they were all trashed. Tons of stuff stuck inside the filter top. Rusted bottoms and all around garbage. Happy I went with my gut and pulled them for inspection. The injectors I brought I have to return. The rebuild quality on them are horrible. I would love to replace the fuel rail too, but haven't been able to locate one. New ones don't exist anymore.
my 88 was same way after it sat 2 years. fuel rail was full of crap too
Replaced the fuel injectors, I have 35 solid PSI at the rail. Sprayed some starter fliud and nothing still won't fire up. Any suggestions? Anyone please!!
I'm going to recheck my timing to make sure that I am not timed on exhaust stroke.
Sorry about your luck! I'm no expert but when is the last time you checked your spark and compression? It seems like you have the fuel system right where it needs to be (assuming you got the injectors plugged back in and are firing). Also, it's unlikely but is there anything blocking the air intake?
Sent from my SPH-L720T using Tapatalk
Nothing is blocking the air intake. I have the tb open right now (took the intake pipe off). I have spark I haven't checked compression in awhile. But here's the thing, it was running just fine, with the help of starter fluid a few weeks ago, sounded healthy and idled great. After I replaced the AIC, then whatever was in my fuel lines from sitting for years clogged up the FPR and then the injectors once I replaced the FPR.
I put the new injectors in the truck and just finished checking my timing which is spot on, and still nothing.:icon_confused: I'm at a loss right now.
Have you tried checking spark at each plug wire ? Do you have a strong spark ? What is your battery voltage before you try starting the engine ? Try shooting carb cleaner in the TB for a few seconds before starting it.
