Clayton
- Jan 31, 2018
It seems insane that this'd be the case, but I can't find after market or OEM exhaust bolt kits for this truck.
The bolt in question is the farthest back (closest to cab), one of two that holds the EGR pressure feedback sensor. It's causing clacking sound and exhaust flutter sound on startup and until it warms up, then when hitting a bump just right a P0443 code (EGR PFS sensor is confused since it's downstream from the leak.)
Anyways, are these really not available? Are people just using hardware store bolts?
