petera
had heat issue running at about 95 degrees (heat gun)found thermostat locked open damaged gasket--replaced housing gasket and thermostat with morad parts --still themp only reached 120--after scanning y-tube someone stated if thermostat and gasket don't fit snug water escapes through and still won't build temp-replacing with oe motorcraft housing and stant 45829 when they arrive will let know this is 1995 2.3l automatic--don't appear to be oe thermostats avail
