1998 Ford Ranger XLT Speedo, Odometer, shifting, and more please help
JacobMoonsMocs
Usa
So me and my dad have been loving this site you guys have been extremely helpful so far but I cant find anything about this issue OTHER THAN the speed sensor.
Let me start in July of this year when I got the truck. Its a 1998 Ford Ranger XLT automatic v6 3.0 L. Rear wheel drive
Truck looks great and pretty nice to drive but a few issues were noticed when test driving it.
1st the Speedometer was not working (it wasnt moving at all) and as much as I would love to say " why no officer my truck always tells me im under the speed limit." I dont think it would fly over too well.
2nd tripometer and odometer dont work (Not turning)
3rd Cruise control doesn't seem to work however the buttons on the steering wheel AR in pretty rough shape
4th Overdrive light is flashing
5th Check engine light is on and the code says its the Vehicle Speed Sensor
6th the truck Automatic shifting is off either it over revs or shifts hard slinging you forward
We replaced the speed sensor as everything seems to point to it but when we did all problems continued except it shifted even harder to the point where it felt like we were getting hit in the rear
So we kept reading and said oh it must be a bad sensor so lets try another one well we tried like 3 and finally gave up went to a junkyard and pulled one from a broken down ranger and threw it in
Well basically I'm back to square one all the same issues but it doesn't shift as hard
Ok so now in August I was driving and lost all power my engine over heated and thanks to this website and all of you amazing writers we spent the last 2 months working to rebuild this truck from warped Heads and a broken head gasket
We finished the repair yesterday and it drives great other than issues listed above I Love this truck its my first car and I want to take care of it any advice would be really helpful
Thank you,
JacobMoonsMocs
If there is a better place to post this let me know
Thanks
Jacob
Check the harness/ wiring to the speed sensor.
clear the codes, see if they come back.
Other than that, it looks like you have covered what needs to be covered. I will let the more able-minded and smarter people chime in :)
AJ
When I had a similar problem in my 2000 B3000, it was due to water/liquid accumulation under the driver seat.
There is a harness connection there that happens to be the lowest point there. Has to be unbolted from underneath (10mm) and dried out both from the inside of cab and under cab.
Had to use alcohol, electrical contact cleaner and hair blow drier during Texas summer to finally dry it all out. Yes, disconnect the battery!
Ray
We are thinking a wiring issue does anyone know the correct Amps and Volt readings from the rear differential speed sensor on a 1998 ford ranger
