1998 B4000 front end camber
Stereodoc
I seem to have a camber issue with my B4000. The front wheels lean in at the tops or the bottoms lean out. A garage I take it to say there's nothing that can be done to fix that except to replace the ball joints. The truck has 150,000 on it so I wouldn't be surprised however the ball joints are still tight. Can the camber be adjusted on this vehicle? My tires are wearing on the inside edge. A little research seems to indicate that a camber shim can be place to correct and do an alignment. Is this true?
