1998 3.0 high idle when clutch is pushed in UPDATE
dmb2613
2.3 (4 Cylinder)
It is worse when it is cold , engine reves to 3000 at stop sign [ manual trans] it will come back down but takes a minute or two. I installed a new IAC valve same thing.
Thoughts please
Thanks David
Vacuum leak...
smoke test time
cant find any vacuum leaks, it will come back down to an idle , about 700 rpms when I stop, idles fine until I drive it, does not go to very fast idle [3000 rpms] all the time.
you sure the throttle cable isn't sticky or hanging open?
today I unplugged the IAC valve and no more fast idle, works fine so there is a problem with the signal coming to the IAC vale , thoughts please
If the truck idles more then about 500 rpm... you have a vacuum leak or maybe someone has adjusted the throttle stop screw?
When the IAC is unplugged... the engine should nearly stall or stall. It would most likely stall if you put it in gear.
Can you read TPS data? At closed throttle TPS voltage should be less then 1 volt.
idles around 500 rpm
Still idling around 500?
Yes, but I hooked it back up this morning
smoke test time
I got a Motorcraft one today and all is well. the aftermarket ones dont work for me
New just means not tested to me. There is a way to set the idle stop screw, tech section.
