1997 Ranger w/ 1993 Mustang 5.0
MeanGreen3.0
I picked this jewel up for $2300 a couple weeks back. The swap was allready completed and the truck does run. I drove it 90 miles home the day I bought it. I am trying to tie the loose ends up.
All this was done befor I bought it.
Holley Systemax Upper and lower with spacer
BBK 70 or 75mm
BBK CAI with K&N conical filter
It does have Heddman Swap headers.
It also has a pretty healthy loping cam.
It does not have an EGR sensor or Smog Pump. Being a mechanic in training I know the EGR is semi important. BTW the plugs to these are just hanging. I taped them up for the time being.
The headers or throttle body do not have a provision for the egr.
The Baro sensor seems to be unhooked with a cap over the 3 pin connector. The intake for the sensor has the normal white air cap.
Now I experienced a bad miss after a radiator hose blew out. I dried my engine compartment with a hair dryer and dry comptessed air. This prompted the connector taping. LOL I solved that or so I thought. On the way home it missed bad. but even through the missing from the radiator hose i could clutch it or go WOT and it would miss and take off like Satan's Chariot. Today it just missed untill I revvd real hard once or twice.
Since the hose incident I cleaned all plugs and Distributor cap and rotor button as well as extremely greasy Coil to Dist wire. Also cleaned and re oiled K&N (was extremely filthy).
Any help would be lovely. I'm stumped.
Did any moisture get under any of the plug wire ends? That can cause your engine to miss very easily.
Sent from my A500 using Tapatalk 2
