1997 Ranger 4x4 Splash, will a 1997 4.0 Explorer 4x4 Engine donor work?
Swurv
Guam
2.9 V6
Greetings, I have a 1997 Ford Ranger 4x4 3.0 V6 that spun a bearing. It needs a donor engine and I'm looking to get it replaced and up and running. My 2 options are to get a crate from Jegs or Summit or take it out of my donor 1997 Ford Explorer 4.0 V6 4x4. Will this work and convert easy or should I just go with the crate option? The condition of the Ranger requires some minor body work and a good undercoat. I'm trying to weigh out my options and would greatly appreciate any input and insight.
Thanks!
Easy............no.
1997 Ranger has a 3.0l computer so can't run a 4.0l engine
And the 4.0l engine won't bolt to the 3.0l transmission
You could swap over 4.0l engine/trans and mounts with the 4.0l computer and engine wiring harness, and probably the exhaust system as well
But getting close to same work as a V8 swap, not quite but close
IMO, you would be better off swapping out the 3.0l for another 3.0l, plug and play
Then look for a 4.0l Ranger(or B4000) with good body and bad engine and/or trans and use your donor to fix it
1997 Explorer was the first year for the 4.0l SOHC engines as an option, you need to see which you have, Rangers used 4.0l OHV from 1990-2000 then got the SOHC model in 2001 and up
These are different engines so use different computers but they used the same block so either will bolt up to a 4.0l transmission
4.0l SOHC will have "4.0l SOHC" stamped into top plastic cover on engine, easy to spot
Easy............no.
Thanks, for the info. I'll look into the plug and play option to get it going.
Easy............no.
Isnt one bellhouseing bolt different between the OHV 4.0 and SOHC? Not really allowing it to bolt up?
No, Ford added an extra bolt hole on the SOHC block and also Bell housing but the other bolt holes all line up fine, so swap of transmissions between 4.0l OHV or SOHC has no issues, auto or manual
Side by side image here: https://therangerstation.com/wp-content/uploads/2017/06/45-vs5r_bellhousing.jpg
On the right is the SOHC, has the extra bolt hole at top left
Left picture is the OHV
Arrow is pointed at the starter motor difference between 4R and 5R automatics
