CAJones
- Oct 28, 2018
- Seattle, Washington
- 2.3 (4 Cylinder)
- Manual
Thanks for everyone who has posted content on how to do stuff, I have used Ranger Station quite a bit already!
I just bought a '97 Ranger 2.3 with a 5 speed manual to use as a shop truck. The engine was rebuilt by the previous owner who was a mechanic, it now has 150k on it since it was rebuilt.
It has thrown three codes total:
When I first got it a month ago it threw 401 (EGR flow insufficient) and 420 (catalyst system efficiency below threshold). I replaced the O2 sensors as they were cheap from Rock Auto and it passed Washington emissions, however they came back on my way home from emissions testing. It just gifted me 301 (cylinder 1 misfire) and now a blinking check engine light, which it did about a mile from my house so it hasn't been driven long with the misfire.
I changed all eight spark plugs, since I don't know when they were last changed) with Autolite A104 (~0.045 gap on each one) and AC Delco 954Q plug wires. I also found a blocked passage from the EGR into the intake, I cleaned that out hoping it would resolve the 401 issue. I also cleaned the IAC as well with carb cleaner. The battery was unplugged overnight to reset everything.
Here are the symptoms I now have:
-Rough/bouncing idle to the point it is undriveable unless I use way to much gas to get it smooth
-If I step on the gas, the engine seems to run just fine
-Strong smell of gas from exhaust
-I can't test the EGR valve or really anything else because it dies immediately.
-Fill the tank up twice so far, average was 20 and 22 MPG.
It won't throw any codes since I can't drive it for it to reset all of the computers. Not sure what to check/change now to get it to at least idle on its own.
