SoCalGal
- Apr 27, 2014
- Manual
I was driving to the store the other night and my truck died. First thing I thought was, out of gas. But it didn't die like it had run out of gas, no sputtering.
Turn the key, it cranks,
Along side the road, they checked for spark, checked the fuel rail, said it was getting both. Pulled it home.
Next day, checked with some meter for codes, only code was loose gas cap. Further diagnosis, determined it was one of the coil packs. Replaced them both.
Same thing. Sprayed starting fluid while I cranked the motor and held the gas pedal down, still wont start.
It is a 4 cy motor. Any suggestions would be great. (oh, also checked fuses and relays)
Could this be something in the actual ignition? Or the wiring between the ignition where I turn the key and the coils?
Thank you much
Thank you much
